Car shakes a bit when i clutch in?
    Whenever I'm in first going ~5 mph and I clutch in, something under the car seems to shake or clank around. It seems to be the driveshaft and the vibration or shaking moves to the diff. What could it be?
    Maybe flywheel or the bolts came loose.
    @IRON-E30 aka Edwin:D
      Id get under the car and check to make sure nothing has come loose. The bolts on my drive shaft have come loose before and caused vibrations.
      The Build:
        i had a car that clunked with clutch in, turned out the csb had zero rubber left and the bearing would hit the csb housing.
        '86 Delphin 335i turbo -
        '88 Schwarz 325i -
        '94 w124 e420 -
        Turbo m30b35 Build Thread
