Hey guys,
Probably asked a million times but prices seem to be going up on e30 stuff and i wanr to make sure im not getting ripped off...heres the story.
Buying "everything" for a 5 speed swap but the transmission. Im looking for advice because I've never done this before and I'm new to e30s. I also dont know what "everything" means and want to make sure i cover my bases. I have offered $450.00 for the following parts:
Drive shaft
Cross member w/mounts
Master cylinder w/lines
Slave cylinder w/lines
Shifter assembly w/new bushings
Clutch fork
Pedal assembly
Reverse harness
Clutch pressure plate
Flywheel
Throw bearing
Exhaust shield
Is this a good price to pay for these parts? What else would I need to complete this swap? Any help would be awesome
Thanks,
David
Drive shaft
Clutch fork
Pedal assembly
Reverse harness
Flywheel
Throw bearing
Exhaust shield
Thanks,
David
