Clutch Won't Disengage
  • e3irsty
    • Jan 2014
    • 134
    Thought slave cylinder or master cylinder went. Pedal is soft but comes back, no leaks, and everything looks to be fine. It worked before I took the tranny out. I took the clutch and flywheel out and through it all back together. What could I have messed up? Thanks
  • LJ851
    • 7919
    Have you tried bleeding the clutch? It sounds like there is air in the system.
    Lorin
    The M30 is God's engine.
    • e3irsty
      • Jan 2014
      • 134
      Wouldn't it change in pressure in the pedal if there was air in it and I kept pressing the pedal repeatedly. How would air get in it if I only removed it from the transmission and put it back on? Appreciate any help. Thanks
      • whodwho
        • Jun 2008
        • 1547
        Possibly the disk is backwards and hanging up on the hub
        My M20 Frankenbuild(s)
        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
