Clutch dropped to the floor
  • fakeplstctrees
    • Jun 2013
    • 92
    So I go to take my E30 out this morning, and barely touched the clutch pedal before it literally dropped to the floor. The car has been performing perfectly, I just had some major servicing done last month. But I remember the last time I drove it, the other night, I pulled out of a gas station and it slightly bottomed out on a steep ramp/curb from the parking lot to the road. Could this have caused my clutch problem? And if so, am I at risk of serious damage? I'm so glad that this forum exists, it's the greatest resource for E30 maniacs!
  • DrJosh
    • 2011
    Probably isn't related to bottoming out. Sounds like something in the hydraulic line failed or the clutch master cylinder failed. A couple places to start would be to check the brake fluid level, or remove the kick panel below the steering wheel and inspect the clutch master cylinder and make sure the pedal is still physically attached to it.
    Originally posted by Sonny
    I am a meme for our community.
    • E30_Pare
      • 7801
      I vote slave cylinder
      DREWLIENTE
      1$ PShops PM me
      • fakeplstctrees
        • Jun 2013
        • 92
        OK, great. Thanks guys. I was just concerned that bottoming out the night before was the culprit, given the correlation between clutch failure, and my first time ever bottoming out.
        • Colby.325e
          • Apr 2012
          • 413
          +1 for slave. Been there. It's a cheap part, and a super quick fix at least..
          1986 325e - RIP
          1987 528e - Sold
          1989 325iX - Parted Out
          1991 318iS - Sold
          1991 325iS - Current
          • Das Delfin
            • Sep 2014
            • 2293
            Probably your slave.. get a new soft line as well since it's cheap enough
            • IceWhite
              • Jan 2015
              • 945
              I had a clutch fluid leak at the slave. I replaced it and two days later had clutch pedal dropping to the floor, turned out the master cylinder went bad and had to be replaced. So I say if you replace the one, then you might as well replace the other.
              1990 325i
              2004 330i Individual 6-speed
              • 5Toes
                • 9836
                Get a SS clutch line from Blunt for $35, the slave is $25 - go with Febi brand or similar.
                The clutch master cylinder is likely about to fail too. Id replace both and do the whole job for around $150 with dot4 fluid
                • jhaurimn
                  • Nov 2012
                  • 2224
                  Dont replace the slave without replacing the master cylinder, or you will ruin your new slave.
                  Current:
                  1989 325i
                  1988 M3
                  1987 325ic
                  Past:
                  2001 330ci
                  2001 M3
                  • McGyver
                    • 4636
                    while you're in there, bleed all your brakes so you have good fresh fluid everywhere. brake fluid is hydroscopic, so it attracts and absorbs water and will rust/corrode your brake lines. so the fluid should be flushed every year or two. (and yeah, it's probably a bad slave. but replace your master and soft line too)
                    • estoguy
                      • May 2013
                      • 1087
                      X3 on doing both master and slave.
                      Estoguy
