used getrag 260 leak in bell housing below input shaft
Mine leaks from the same place.i even did what you did with hondabond and it still leaks
how bad does yours leak? Is it to a point where you drip everywhere you park? Is there another solution or is the trans in need of a rebuild to replace that cap?
