hard shifting into second
    it is hard for me to shift into 2nd gear on cold starts. after a few minutes of driving the problem fixes itself. is anything wrong?
    1991 325ix <<sold
    1997 328is<<brothers
    1999 328i<<pops
    I had that and it turned out to be low fluid. Dont know much about the tranny, but that took care of mine.
      thought that was normal overall with the Getrag trannys when cold
        It is normally difficult when cold. Do you even know they last time fluid was changed? If not, drain it and swap it with redline ATF, that will help.
        Old and improved:
          Redline stopped that on the e30 i bought recently.
            ATF in a 5spd eh? i should try this...my tranny is a biatch when cold also...
            IG: @Baye30
              I used mobile 1 synthetic atf in mine when I had it out, noticed a slight difference.
              Old and improved:
                how about you guys check out which tranny you have first, some of the transmissions used ATF, some used GL-4 gear oil, and I think even a few used GL-5. putting the wrong fluid in is a great way to buy a new transmission.
