Axle stuck in hub
  • jamiholzbach
    • 311
    Axle stuck in hub
    I actually broke the bearing puller trying to separate the drive axle from the hub while replacing the rear wheel bearing. I've beat on it with a sledge hammer, and cannot even move it. Do I have to replace the entire trailing arm, brakes and all? the other side was easy, but this won't budge. Any tips?
  • barry
    • 1642
    Heat it up with a rose bud torch
    • TobyB
      • 5298
      Sometimes they slide right out, and sometimes they are almost welded in there.
      I agree- heat is a big help- and try several heat cycles, too. Not TOO hot, but since you're
      replacing the bearing, you can get it to 500f without any danger...
      Don't give up- they seem to appreciate persistence.
      t
