Transmission Shifter Rod Connector
    My car has a lot of play in the shifter when the car is in gear. I checked all of the bushings and everything seemed to be sound. However I think the shifter rod connector stud could be bad. ( the piece that connects the shifter rod to the top of the transmisson. I figured this out when I was checking the linkage for play and this was the only piece that would allow any movement, thus I suspect the rod connection stud. I am not sure how to replace that piece or how difficult it is. I would appreciate some advice.
    Also When I looked the piece up online I found a picture and it doesn't look like it would have any place to actually wear down and cause more freedom of movement. I could be wrong their may be some kind of bushing at one or both ends.
    that part actually creates alot of play believe it or not, there is a dowl that should be replaced at the same time with it, its not to hard, but the clip takes some fooling around with to get in properly. Easy afternoon job.
    Cam .W '91 325is
    Spaz's 1991 Alpine White???? S52 Build Thread...
      Is it necessary to drop the transmission? Thanks
        no not necessary at all, all work can be done with it in place. the exhaust might have to be removed thou.
        Cam .W '91 325is
