no pressure on the clutch
  • Calypso Moor
    • Sep 2013
    • 91
    so my moms E28 is having problems with the clutch, she gets no pressure pushing it down until about 3 inches from being able to shift. do I just need to bleed the system? or am I looking at new cylinders?
    I did post this in the E28 section but I don't know how much traffic that forum gets.
  • Calypso Moor
    • Sep 2013
    • 91
    the car drives fine and has no problem shifting other than that theres no pressure pushing down the clutch.
      Could be air in the system or a bad master cylinder, assuming no leaks at the slave or soft lines.
      • TobyB
        • 5243
        Got a full brake fluid reservoir?
        t
          I should add that this could also be a problem with the clutch/pressure plate. But go for the hydraulics first.
