Transmission sounds like marbles.
  • lolcantturn
    • 4588
    Sounds like someone threw marbles into my transmission when I'm around 3000rpm in any gear. Shifts perfectly fine otherwise, and makes no rattle at idle. New trans fluid as well. This is a getrag 240.
    Any thoughts?
    Originally posted by TSI
    OEM+
    I don't know what that is and it will likely require a tear down and inspection of the transmission internals to find the problem(s). When you changed the fluid did you see any metal particles in the fluid?
    • lolcantturn
      • 4588
      No metal particles in the fluid or drain plug.
      I'm just as clueless as you are. Never heard such a noise like it before on any of my cars.
      OEM+
      • TobyB
        • 5298
        If you try wiggling the shifter when it's making the noise, does it change?
        Same for putting some pressure on the clutch pedal- not enough to disengage the
        clutch, just load up the pressure plate- and your thrust bearing....
        sure it's the trans?
        Shiny spots underneath, like the guibo's hitting something? Or the exhaust?
        I had a 'failing center bearing' on the E36 turn out to be a soft heat shield that had fallen
        down and was brushing the side of the driveshaft...
        hth
        t
        • lolcantturn
          • 4588
          hth
          t
          Well...taking your suggestion, it was actually the transmission mount that was loose . I wonder how such a things could create such a ruckus. Oh well, all is fixed.
          OEM+
