zf310 input shaft bearing
  • dougie30
    • Apr 2012
    • 1708
    Ok so I bought a zf310 trans from a 1994 530. when i brought it home and dismounted it off the engine the input shaft had a fair amount of play.
    I found two videos in the trans section of the forum saying it is except able because the pilot bearing will hold the other side of the input shaft, but this transmission is fairly hard to find so i really am not trying to blow it up.
    What I wanted to know was if i were to replace the in put shaft bearing could i remove it from the front (the part that bolts to the engine) or do i have to separate the case and take it all apart and push it out from behind?
    Im going to replace the seal anyway so if it pups out the front then i might as well do the bearing too correct?
    M30 is God's motor.....but Jesus drives an M60'd car -slammin.e28
  • dougie30
    • Apr 2012
    • 1708
    Another question, there is a sticker on my trans that says it takes automatic fluid but it is obviously a manual transmission.
    Can someone confirm if this is correct? And if it is what type of fluid would you recommend?
    • TobyB
      • 5280
      If it's like most BMW transmissions, it's a pain to get out. I would not worry too much if
      everything else seems ok. The pilot really does prevent wobble. Now, if it moves fore-
      aft or up- down, (the whole shaft, not just the nose of it) then I'd go in and fix it.
      And yes, atf is one of the several things you put in manual transmissions. I like Redline D4 quite a lot in the one in my E36....
      hth
      t
      • dougie30
        • Apr 2012
        • 1708
        hth
        t
        Awesome, thanks for clearing that up. I think I'm just going to run it the way it is, wish me luck :up:
        • SnowB0und
          • Dec 2016
          • 111
          I have this same question.
          Is yours still running?
