E30 Vibration Dampers
  • trinidee247
    • Sep 2009
    • 10
    I have a picture of this vibration damper that's still jimmied to manual transmission output flange. Can anyone tell me how do i get that out?
    I am hoping not to use my puller on it because it feels like half plastic half steel when I flexed it with a wrench. And I'm hoping that I do not have to get to that bolt in the middle because I need to buy a deep socket to get at it.
    Sent from my SGH-T999V using Tapatalk
  • rcsoundn1
    • Nov 2012
    • 3361
    I am not 100% sure what I am looking at, but from what I see, that bolt has to come off. I may be wrong though
    • ahrensNW
      • Mar 2015
      • 1716
      You're going to have to take the output flange nut off to pull that out buddy.
      Hank Ahrens
      1984 Alpine Coupe
      1978 911sc
      • TobyB
        • 5296
        Huh. Mine was on the driveshaft, not the trans flange.
        But yeah, remove flange, pound out studs, replace with shorter studs.
        t
        • Flash
          • 688
          30mm deep drive, thin wall, impact socket will make short work of it if you have an impact gun. They can be pretty frozen. I had to buy a socket for this son-of-a-bitch bolt and have it machined down.
          • TSI
            • Mar 2012
            • 691
            No, no need to remove the flange. Just pound the guibo bolts out, it will drop out. Make sure it doesn't fall on you though, because it is heavy.
            • TimeMachinE30
              • Jun 2014
              • 3749
              Mine is on the DS, too. Would it do any good there even?
              ACS S3 Build / Dinan 5 E34
