Getrag 260 won't stopping leaking
  • b_something
    • Mar 2015
    • 23
    Any thoughts on what could be causing the trans to continue to leak after both the rear seal and selector seals have been replaced with OEM?
    I can access 4.6 Ford engines, 5.0 Coyotes, 4.8 and 5.3 LSX swaps. PM me if you seriously need one.
  • mikebloco
    • Feb 2015
    • 190
    Did you replace the seal inside the bell housing?
    • ttrousdell
      • Nov 2009
      • 1770
      ^sounds like its only leaking out of the rear?
      Take a look at these threads. Its important to put the sealant on the splines and threads of the output flange.
      The Build:
      • b_something
        • Mar 2015
        • 23
        Front of trans is good, it is the rear.
        • blackis
          • Dec 2012
          • 1
          Output shaft is worn
          • TobyB
            • 5298
            Output flange is worn.
            Fixed that for ya. Or it is loose and leaking out the splines.
            t
            • b_something
              • Mar 2015
              • 23
              t
              Thanks for the input. About to get back in there and find out. I will post the fix once I get there.
              • AndrewBird
                The Mad Scientist
                • 11898
                The flange may have a groove worn into it's circumference. Look into buying a speedi-sleeve for it, or buy a new (or good used) flange.
                • b*saint
                  • 3794
                  Sounds like its not the shaft but rather the bushing it rides in. Very common issues on GM transmission extension housings. Bushing wears and the shaft drops. I highly doubt the lip seal wore out the output shaft (which is welded to an output flange.)
                  Ma che cazzo state dicendo? :|
                  • TobyB
                    • 5298
                    He doesn't have a slip joint on the back of his G260.
                    Nor a bushing for it to ride in.
                    There's a bearing on the inside of the rear housing, and the transmission output
                    flange clamps right against it's inner race. The rear seal then sits right in there, in a recess in the
                    housing,
                    and the seal rides on a smooth surface on the output flange. It's similar
                    to how the nose of the crank seals with the crank pulley/harmonic balancer.
                    They CAN get a groove worn into them, just like a crank pulley. You'd a thunk
                    they'da checked it when they changed the seals, but...
                    Now, if he's swapped out the G260 for a TH350, that's a different matter...
                    t
                    • efficient
                      • Feb 2012
                      • 3312
                      Mine leaks and smells burnt after drives. And now it's starting to feel super notchy. I think I'm super low on fluid now
                      • b*saint
                        • 3794
                        housing,
                        t
                        Lol okay thanks for the clarification. You know I knew that too but its been so long since I worked on a 260 and I just have a 4l60 all apart.
                        • b_something
                          • Mar 2015
                          • 23
                          I believe the seals were not properly installed the first time. I installed a new rear seal and selector shaft seal and now I am leak free.
                          Try, try again!
