G240 Likes to Whine
  • MouseRat
    • Nov 2015
    • 75
    G240 Likes to Whine
    Hello,
    I have a bit of a whiny issue with my '91 318iS.
    It seems to be coming from the transmission and it only happens when the clutch is engaged (never without). I can provide a small sound clip if it would make things easier, but it's louder/more noticeable at low speeds and the pitch increases with speed.
    I'm sure its not the diff as that has just had new fluid along with driveshaft oil seals.
    Help much appreciated
  • glnr13
    • 1334
    throwout bearing
    • MouseRat
      • Nov 2015
      • 75
      Originally posted by glnr13
      throwout bearing
      Cool.
      I'm guessing its also a good idea to replace the clutch disk itself and pressure plate while I'm in there too. Is the Sachs Kit a good buy?
      • TobyB
        • 5298
        If you mean, when your foot's on the pedal it whines, then I agree, throwout (or long shot, pilot)
        Yes, the Sachs kit is proven to be good value for money.
        t
        • MouseRat
          • Nov 2015
          • 75
          t
          Ahh, sorry for the confusion, it whines when my foot is not on the pedal - when the car is in gear and I am accelerating.
          Thanks
          • glnr13
            • 1334
            Then that is not the throw out bearing
            Sent from my SAMSUNG-SM-N920A using Tapatalk
            • MouseRat
              • Nov 2015
              • 75
              Would replacing the tranny fluid be of any benefit too?
              Quick Video where you can here the whine. From about 00:26 when I pull away in 1st gear.
              • TobyB
                • 5298
                Sure, try the fluid, but don't get your hopes up.
                Transmission whine usually means countershaft (layshaft) bearing failure.
                t
                • MouseRat
                  • Nov 2015
                  • 75
                  Ouch. Doesn't sound too fun!
                  Might have to be on the lookout for a new box - it might be cheaper than the costs associated with fixing it/getting it fixed.
                  Thanks for the help!
