UUC black trans mounts, engine vibration
  • econti
    • May 2014
    • 1152
    I just installed some UUC Black trans mounts. No enforcer cups.
    The installation went as follows:
    -remove old mounts and crossmember, trans on jack
    -new mounts on crossmember
    -align crossmember, tighten to car
    -remove jack, trans sitting on untightened mounts
    -tighten until the washers are just snugged up between nuts and mount/crossmember
    There's now a decent vibration at idle and at other points in the rev range.
    Did I wiff the installation, or is the problem elsewhere?
