anyone ever used a valeo clutch??
  • ///digitalme
    • Dec 2009
    • 2088
    I have to do the rear main seal on my 318is. The clutch was replaced about a year ago but not aligned with a tool just eyeball. Ever since ive had clutch problems where its hard to shift from time to time or slips at high rpm. I want to replace the clutch and flywheel. I found valeo makes a solid flywheel clutch kit combo for about 417 dollars. I was wondering if anyone has used a valeo clutcb and if therea any issues with them? My car is stock and plan to keeping stock.
  • hyperE30
    • Sep 2009
    • 2202
    Compra un luk/Sachs clutch kit y luego resurface the flywheel, te sale mas barato.
    HyperWerkz
    89 mtech2, s50, AR Kit, borgwarner s362, e-85, 15psi... 592whp
    " enjoy the show "
    • TobyB
      • 5296
      Valeo is stock on later cars- they make decent stuff.
      but centering has no effect on clutch performance, only your stab experience...
      mais non, pas de resurface...
      t
      • ///digitalme
        • Dec 2009
        • 2088
        Thanks for the suggestions, i was going to do an m20 clutch set up, but i believe theres not much benefit to it. Since the whole m20 set up weighs the same as an m42 set up. I talked to a shop and said people are weighing just the flywheel when youre suppose to weight it with the clutch and pressure plate. After searching ill stick with a new m42 flywheel and new clutch and make my life easier though its more expensice than an m20 kit, but i need to do it asap
        Thanks for the input
