Vibration dampener ring twists off?
  • Beej '86 325es
    • 2639
    This vibration dampener ring thing is supposed to twist 60 degrees to come off, ya? Do I have to take off that nut in the middle?
    -Brandon
    '86 325es S50
    '12 VW GTI Autobahn DSG
    '03 540i M-Sport (sold)
    '08 Jeep SRT-8 (sold)
    For sale:
    S50 TMS chip for Schricks
  • matt
    • 3732
    *Damper
    You have to pull out the washer around that nut, remove that nut, remove the output flange, remove the damper from the output flange then reinstall.
    Matt
    • Beej '86 325es
      • 2639
      cool, thanks. Any idea what size that nut is? I'm going to have to buy a new deep socket.
      -Brandon
      '86 325es S50
      For sale:
      • rs4pro3
        • 5808
        on the e30's it's 30mm , can't tell if that's an m20 or e36 tranny. You may have to grind down the outside of the socket to fit down into the flange.
        85 325e 2.7 ITB'd stroker
        • DEV0 E30
          • Oct 2004
          • 8903
          Thinwall 30MM on E30s, I got one at Ace. Good luck getting it off though, and don't rest the torque wrench on the tranny tabs, or anything - trust me.
          • Beej '86 325es
            • 2639
            Thanks guys. One more question...
            How did you hold the shaft still when you loosen/tighten the nut? It almost seems impossible unless it's installed to the engine.
            -Brandon
            '86 325es S50
            For sale:
            • matt
              • 3732
              Impact gun.
              • ldsbeaker
                • Aug 2004
                • 3098
                Is this that "15 min job" that's supposed to cure my non-bended selector rod grinding issues from the z4 3.0 SSK?
                Slicktop City!
                • 92 mtechnic cabrio
                  • 4907
                  guess so, although my vibration damper was ON the driveshaft, not the end of the driveshaft.
                  R.I.P 07/01/09 - 04/23/10 :(
                  • AdamF 88iS
                    • 2051
                    Later cars are like that.
                    You have to pull the flange off and bang those studs out of the flange so the dampener can be removed. In the bently it says rotate 60* but it doesnt tell you that that's after you knock the bolts out.
                    Adam Fogg- '88 M3
                    Common sense- It's the new 'gifted'
                    • DJB
                      • Oct 2005
                      • 195
                      Here are my notes, although I haven't done the job yet:
                      23-12-1-282-394 Shift shaft oil seal, 15x21x5, $8.60, $2.35
                      23-12-1-205-340 Transmission output shaft seal, 40x55x8, $12.40 , $2.95
                      23-21-1-490-120 Safety plate/Lock plate, driveshaft output flange, $0.85/$1.33
                      Socket needed 30mm (1-3/16" = 30.16) deep thin-walled socket
                      Maximum diameter 1.521" or 38.6mm OD, although 39mm may work
                      Interal relief: minimum diameter of 15.5mm to 70mm deep
                      • Garageaholic
                        Freestyle Fabricator
                        • Dec 2005
                        • 5204
                        Does one really NEED that dampener? What exactly does it do and how effective is it? (don't say it dampens vibration...)
                        Recent Rebranding!!
                        E30 SM62/S62
                        E30 M60 V8
                        E30 M30 Big 6!
                        Instagram.com/garageaholic
                        Youtube.com/garageaholic
                          • 4907
                          I didn't feel the slightest difference without it.
                          • Beej '86 325es
                            • 2639
                            You are the man!
                            -Brandon
                            '86 325es S50
                            For sale:
                              • 34844
                              make sure you use the correct sealant on that output flange (curil K2) and that you torque that nut down correctly when you put it back together. if you don't, you get leaks!
