e36 trans fitment on e30
  • helalo
    • Oct 2012
    • 93
    will the manual e36 m3 transmission fit my e30 325is ? my e30 is auto im switching to manual.
    the e36m3 trans was used on other bmws non-m too right ? 528i and z3
    what else would i need to switch, besides the transmission.
  • emripires
    • Dec 2015
    • 74
    ZF 310/20 was used on 2.8l cars also the m3s. Should bolt up to yours.
    • stonea
      • 2890
      Yes and no, the zf will be clocked 10 degrees, so you'll needs custom trans brace and twist the shift linkage. Like the opposite when people pair the G260 with the 24v engines.
      My Garage
      Feedback
      Instagram: Stone.Hopkins
      • helalo
        • Oct 2012
        • 93
        so its a better option to do a manual swap when i do the engine swap than fitting a zf to a stock 325is.
        im not mechanically knowledgeable but a custom trans brace and twisting a shift linkage sounds uneasy to get/do when i ask my uncles shop to do it.
