upgraded shifter carrier bushings
    • 34847
    I'm looking for something other than the OE rubber bushings, but I can't seem to find anything. derlin, solid, whatever. I have all new bushings and mounts and it's just too sloppy for my tastes. or are you guys just making your own?
    • 34847
    looks like AKG sells poly bushings for the shifter carrier:
    http://www.akgmotorsport.com/e30products.html
    anyone else?
    • e304me
      • Feb 2006
      • 1374
      what i want is soemthing for the back mount
        • 34847
        you mean the mount right behind the shifter? I haven't seen anything for that, would be nice though.
        • Sean
          • 5793
          I would think that back one would have to remain rubber.
          Why? Well, the tranny and engine move quite a bit when driven hard. Making that rear mount solid will only cause a lot of undue stress on the shift carrier - since it'll be attached to the tranny AND attached to the body of the car.
          If you make the front shift carrier moutns stiff - the rear won't help much more.
          I got mine from UUC Motorwerks, Chris. I also jamed a couple washers in there to tighten it up even more.
          They're hard to find - but get to UUC's listing page, and just start goin thru the pages. Can't miss em. They are delrin bushings.
          - Sean Hayes
          • X2theZ3
            • Mar 2004
            • 932
            I have the UUC ones as well and am pleased with them.
              • 34847
              good point about the tranny movement. I need to replace my tranny mount too, I couldn't find my new one when I was putting everything together so I just left the old 218k one in - talk about sloppy!
              thanks for the link, I'll probably pick up the UUC derlin bushings.
              • Garageaholic
                Freestyle Fabricator
                • Dec 2005
                • 5204
                Good point Sean. I have been having the same problem because I DID bolt mine to the frame pretty much.. and downshifting or quickshifting into second gear after a quick acceleration spurt, it was difficult to get it into second gear..
                On the highway the shifting is fine, but even with poly tranny/engine mounts, it STILL moves.
                Good point
                Recent Rebranding!!
                E30 SM62/S62
                E30 M60 V8
                E30 M30 Big 6!
                Instagram.com/garageaholic
                Youtube.com/garageaholic
                • e304me
                  • Feb 2006
                  • 1374
                  what about mouning the whole carrier to the tranny tunnel?
                  • Garageaholic
                    • Dec 2005
                    • 5204
                    How are you going to mount the ass end of it then? it will just hang...
                    Recent Rebranding!!
                    E30 SM62/S62
                    E30 M60 V8
                    E30 M30 Big 6!
                    • Sean
                      • 5793
                      Either way - your shift linkage is connected to the transmission somehow.
                      At a certain point, you eliminate that advantages of having a very stiff shifter.
                      Doing that would make it stiff - but would EASILY cause misshifts. Think aboiut if. If the shift carrier was mounted to the body rather than the tranny - the selector shaft (part on bottom of shifter than selects the gears in the tranny) will be moving - so if you try to shift in a turn, maybe you'll go into first instead of third? Which...would be bad in most cases.
                      Pretty straight forward. Doing what I did has made it VERY stiff and VERY precise. Even with the somewhat sloppy Z4 3.0i shifter (the lever has a lot of play in it) it is still very precise. I bent my selector shaft a bit too - since if you think about it, you have more leverage on the selector piece on the selector shaft if the shift lever goes in level with teh shaft - before it was at like a 35o angle - now it's almost horizontal with it.
                      - Sean Hayes
                      • Beej '86 325es
                        • 2639
                        I'd like to know the dimensions of that delrin bushing. $25 is so overpriced for those things unless they're making them custom.
                        -Brandon
                        '86 325es S50
                        '12 VW GTI Autobahn DSG
                        '03 540i M-Sport (sold)
                        '08 Jeep SRT-8 (sold)
                        For sale:
                        S50 TMS chip for Schricks
                          • 34847
                          yeah, but I just want to buy something and put it in. I don't have time or resources to make my own.
