Fluid for G240 and locating whine
  • gespinal0301
    • Jan 2011
    • 317
    I was wondering what fluid you guys run? I have a whine and I'm not sure where it's coming from. It only happens when I'm on the accelerator and if I coast in neutral there's no whine at all, so I'm leaning towards the tranny. Any help would be appreciated
    My Daily Driven 318is
  • TobyB
    • 5258
    I'm leaning away from your tranny and towards your diff. Especially if it makes
    the same whine in different gears.
    redline MTL in the trans, unless it whines, then MT to see if that quiets it a bit.
    80w90 redline in the diff, unless it whines ,then 80w140 to see if THAT quiets it a bit.
    hth
    t
    • gespinal0301
      • Jan 2011
      • 317
      hth
      t
      I'm going to get a new diff and see if that solves the problem, hopefully it does cause it's getting wayyyyy too loud
      • TobyB
        • 5258
        Does it sound the same in 4th as it does in 5th?
        That's a sure sign it's the diff.
        hth
        t
        • gespinal0301
          • Jan 2011
          • 317
          hth
          t
          Yeah it does, thank you! You took out the uncertainty in my mind lol
          • TobyB
            • 5258
            No probs- you might try a fluid change first, since it's so much easier and cheaper...
            t
