dual mass flywheel clutch?
  • cpandrewschmidt
    • Oct 2014
    • 88
    Hi all,
    Going to do a 5 speed swap. Trans will have the dual mass flywheel. I prefer the smoothness as I don't track or drive hard so don't need the single mass. Won't ever turbo the car. Just a convertible cruiser.
    I need a new clutch and pressure plate. Sachs FX heavy duty clutch and plate new on ebay is $125. Again, don't need anything fancy, just need it to work. So, don't want to spend a ton.
    http://www.ebay.com/itm/SACHS-FX-HEA...NRw5X2&vxp=mtr
    Will that work for dual mass? I can't seem to find anything that is specific for dual mass. When I look at PelicanParts I only see ones that aren't suitable for dual mass.
    Thanks for the help,
    Andrew
  • cpandrewschmidt
    • Oct 2014
    • 88
    hi again, anyone with some thoughts on this? Thanks!
    • shoshottz
      • Jun 2016
      • 128
      these at mt subforums are dead..HELP US! WE'RE STRANDED ON CLUTCHLESS ISLAND!
      shottz.
      • TobyB
        • 5296
        Buy your clutch from somewhere that knows the difference, because the pressure plates are different.
        Your ePay seller doesn't know, or is listing the solid flywheel version. I can't tell.
        Blunt pops to mind. www.blunttech.com, and calling him is very much OK.
        When I did this 4ish years ago, tho, the Sachs kits were wrong-
        the dual and single parts numbers in the parts chain were reversed.
        Which is why I'd buy from Blunt- he'll know which is which.
        Plus, it sounds like you need some ice cream... after all that island time.
        t
        • SkiFree
          • Jun 2011
          • 2766
          ^Toby beat me while I was putting the kids to sleep!
          That listing is for a single mass setup.
          Here are listings by people who know better (took me 5 minutes)....
          http://www.pelicanparts.com/catalog/...Tclutc_pg1.htm
          or of course, shoot blunt a call. Either way, good luck on your project.
          ADAMS Autosport
