my porsche was over hauled by my dad before i was born and its soon to become my car. i was wondering how can find out if it has a las or open diff without doing a burnout. i could not find anything on the internet. mostly everything is upgraded
how to tell if u you have a LSD or open diff
Lift the back end of the car so both rear wheels are clear of the ground. Give one of the rear tires a spin. Watch them both. If they both spin in the same direction you have an LSD. If they spin in opposite directions from one another you have open gearing.
Doing a burnout would be more fun though. -
Originally posted by Kmani did a burnout but on my street i couldn't tell so i will do the tire spin thingOriginally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.Comment
Originally posted by Mike325Go back to where you did the burnout. If there is two lines, you have LSD. If one line, open.
Just jack it up and spin the wheels manually like the stated post above.Comment
He's just an impatient moron .
And the jack it up and spin a wheel test does not work exactly as described above .
Even a open diff could spin both wheels in the same direction if you just turn one of the wheels .
In our cars you have to either hold the input shaft still or hold one of the tires while turning the input shaft .
On his Porker with a transaxle I would suggest leaving the car in gear and then turning one of the wheels .Comment
Lsd?
Hi guys,
I'm just bought a 325i and the specs in my VIN shows that my car should have an LSD. However, when I had the car on a lift and spun one of the tires, the other spun in the opposite direction. Is this the only way to check the LSD? Should the wheels spin in the same direction even without any resistance on the tires?
Also, the tag on the diff read 3.91. I couldn't tell if it had an "S" or not. Does this help?
Thanks!Comment
