early g260+early single mass+late clutch=?TOB?
  • rede30
    • 4697
    I have an early g260 with the deeper bell housing. I also will be running and early thicker single mass flywheel, not 885 single. I have late single 6cyl single mass clutch setup. I don't know what throw out bearing to use. Seems like I could almost use a standard TOB because the deep bell housing accounts for the thicker flywheel.
    Any ideas?
  • TobyB
    • 5296
    All I got is that the dual mass and single mass pressure plates
    are significantly different depth, so that might hose you.
    I seem to recall that the single plate is DEEPER than the dual, but it's
    been years...
    t
    • rede30
      • 4697
      Yeah the thicker single mass flywheel is about 1/4" thicker and the deeper bellhousing is about 1/4" deeper.
