Quick! 5 speed swap flywheel position notch
  • cpandrewschmidt
    • Oct 2014
    • 88
    Hi all,
    In middle of 5 speed swap. Keeping the Dual Mass flywheel. There's a little notch welded on it, i assume for timing. Does it matter where that notch lines up when putting the flywheel on? THx
    Andrew
  • LJ851
    • 7919
    Originally posted by cpandrewschmidt
    Hi all,
    Andrew
    BMW uses a locating dowel in between the crank and flywheel on one flywheel bolt to locate the flywheel correctly.
    It only goes on one way when installed properly.
    Lorin
    The M30 is God's engine.
    • cpandrewschmidt
      • Oct 2014
      • 88
      thanks, Im hoping i have it right then! the holes for that dowel all looked pretty similar on the flywheel. hard to tell but it did go one so I assume it's right
      • LJ851
        • 7919
        Like this.
        One of the holes in the flywheel is larger than the rest to accommodate the dowel.
        Lorin
        • jeffnhiscars
          • Jun 2011
          • 6011
          Wouldn't the flywheel position only matter on an E where younhave sensors in the bell housing rather than up front ?
          Alice the Time Capsule
          • cpandrewschmidt
            • Oct 2014
            • 88
            good question, not sure. Bellhousing did come from an '87 e with dual mass flywheel. It has two sensors in the new bell housing. It's being swapped into a 91 325i vert.
            • jeffnhiscars
              • Jun 2011
              • 6011
              I swapped an ETA 5spd into my Cabrio and we just cut the wires off the sensors and left them there to plug the hole. I also swapped to an RHD 7 lb flywheel which to my collection, was not machined for a dowel.
              I just don't see what purpose it serves
              • cpandrewschmidt
                • Oct 2014
                • 88
                Thanks Jeff, good to know I don't need those wires. I'm sure I would have been searching for hours to where they'd go!
                Last question. Do I need to plug the holes on the radiator where the cooling lines came out for the auto? Don't want to start it up and have a mess if coolant will pour out :)
                • LJ851
                  • 7919
                  The transmission cooler section is separate from the main radiator, the only thing that would leak out of the holes would be residual transmission fluid.
                  I left mine open when I converted my car.
                  Lorin
