Transmission clicking noise
  • RainRider
    • Aug 2014
    • 362
    I reinstalled the diff after replacing subframe and trailing arm bushings. The diff bushing was replaced also because the (solid) rubber had loosened from the sleeve. When I bolted up the diff it lined up great but I had to bend the rear diff mount a bit to fit. I did not do anything with the driveline except unbolt it from the diff. Now I'm getting a clicking noise from the transmission/guibo area. Do I need to like adjust the driveline? Am I supposed undo the large nut on the driveline and maybe release any stress?
  • TobyB
    • 5296
    Yup.
    Also look at your csb/rear trans mounts and shift platform- sometimes
    things are super- cozy around the shifter...
    t
    • RainRider
      • Aug 2014
      • 362
      Thanks, ya I'll do it tonight.
      • RainRider
        • Aug 2014
        • 362
        Turned out to be the passenger side parking brake. Noise traveled up the cable to the center console.
        • TobyB
          • 5296
          hee hee- thanks for the followup!
          t
