Driveshaft/mount question: swapping ZF Trans from an E36 M3 into my M42 318iS
  • mcdougz
    • Jan 2017
    • 1
    I have a 318iS that I'm swapping an E36 ZF Manual Transmission into. I've been searching and I can't find any details on this. Will I need a stock driveshaft from an E36 M3, or will the stock driveshaft from the M42 drivetrain fit?
    I'd appreciate any references or links you can share as well!
  • TobyB
    • 5296
    Wild- assed guess? I don't think either will work.
    But I'm basing that on the 240 being very different to the zf, and the e30 being very different to the e36...
    t
    • nrubenstein
      • 3148
      t
      A 4-bolt E36 M3 driveshaft will work just fine, once the CSB is changed out.
      Only a large giubo E30 driveshaft from an M3, or certain early 325s will work.
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
