5 speed getrag stuck in 2. gear
  • serhat06
    • Feb 2017
    • 9
    e30 5 speed getrag stuck in 2. gear how can i take the transmission apart? any one did it before?
  • TobyB
    • 5298
    It's not easy.
    You pull the front bellhousing
    and case off the back....
    t
    • serhat06
      • Feb 2017
      • 9
      Originally posted by TobyB
      It's not easy.
      t
      i removed all the srews front and back it moves but the rear housing wont come off complete
      • TobyB
        • 5298
        I think the next step is to pull off the input shaft bearing- you need to be creative...
        The factory tool fit in between the balls, if I'm remembering the right transmission.
        But it's been a long time. If the Bentley doesn't explain, then there's a factory manual
        out in the internets that does- I've seen it, but I can't remember where, sorry...
        t
