1991 318is Smooth Shifting to Clunky after clutch change
  • elbrack
    • Jul 2013
    • 176
    Had the clutch assembly replaced recently and it was shifting buttery smooth for a few weeks and then went back to feeling clunky on the shifter. Clutch actually feels ok but the shifter is a pain in the ass again with the notchiness/clunkiness.
    It's not smooth and seems to hang a bit on 1st and 2nd.
    Any idea what is up?
  • vpilarrt
    • Jun 2006
    • 2096
    I'd look into the hydraulics. Sounds like the clutch may not be fully actuating when the pedal is depressed.
    • gart
      • Jul 2012
      • 295
      What's the condition of your motor and trans mounts?
      89 325 cabrio in progress m52tub28 swap
      99 540it
      86 Volvo 240 wagon
      99 Cherokee
      13 Passat
      • elbrack
        • Jul 2013
        • 176
        Recently replaced.
        • elbrack
          • Jul 2013
          • 176
          Clutch stop maybe?
          • AndrewBird
            The Mad Scientist
            • 11898
            If you pump the clutch 2-3 times, does the clunkiness go away?
            • elbrack
              • Jul 2013
              • 176
              No, it didn't. Took it into my shop for suspension and had them take a look. They said it felt ok to them and recommended removing the clutch stop. Seems a bit better, but still not that silky smooth it was in 1st and 2nd when I first got it all changed out. Who knows?
