# of torx bolts?
  • Mike325
    • Mar 2006
    • 3685
    # of torx bolts?
    I am removing my manual trans from my 87 325e. How many female torx bolts are there that hold the trans on? Looks like there might be 4. Anyone know?
    Thanks.
    Originally posted by Kershaw
  • SchnellerVert
    • Sep 2005
    • 3948
    E10 I believe. buy a complete set from Sears, they sell Lisle tools.
    • Mike325
      • Mar 2006
      • 3685
      No, I mean how many bolts are there that hold the trans to the engine.
      • Sean
        • 5793
        4 hold the trans to the gnine, they are the larger size. 4 smaller ones hold the tranny to the adapter below the engine.
        - Sean Hayes
        • Mike325
          • Mar 2006
          • 3685
          Thanks for the reply. Are the 4 smaller ones you are talking about torx as well? Do I have to remove the starter? The Bently says you don't.
            • 34847
            there are actually 3 different sizes.. be careful not to strip them, they are a bitch!
            and yes, you must remove the starter, or the backing plate between the engine and tranny gets caught on the flywheel.
            • Mike325
              • Mar 2006
              • 3685
              Ok, thanks. I have the 4 torx out and after I get the starter out I should be able to remove the trans right? All I see is the 4 torx bolts.
              Thanks.
                • 34847
                you have to remove the ones on the adapter too, or it will get caught on the flywheel as well. but otherwise, yes. and don't forget the hex bolt on the passenger side that bolts the covering plate to the transmission..
                • Mike325
                  • Mar 2006
                  • 3685
                  Wow, the bently forgot to mention a little bit of stuff. Thanks man.
