Has anyone ever used Cadillac CTS gears in a BMW case?
  • The Dark Side of Will
    • Jun 2010
    • 2796
    In '03/'04ish the Caddy CTS used the Getrag 260, but with a ratio set that included a 3.57 first gear. This is a lot better for higher powered engines than the 3.82 BMW gear. These transmissions are pretty rare. I bought one, but since I'm in Afghanistan, I won't be able to play with it for a while.
    Has anyone put Caddy guts in a BMW case?
  • TobyB
    • 5296
    No. That would be wrong.
    Just wrong.
    heh
    t
      • Jun 2010
      • 2796
      Not sure how I missed the reply...
      Why would it be wrong to put Cadillac parts in a BMW? ;)
      They're still made by Getrag.
      • TobyB
        • 5296
        Because then you'd drive like my grandad!
        What Caddelyacks got g-260's?
        t
          • Jun 2010
          • 2796
          I don't think your Granddad ever drove a stick shift CTS.
          • TobyB
            • 5296
            I don't think so, either. Park Avenue for one, Delta 88 for the other.
            I don't see many cts' in the yank-a-part, but I'll keep an eye out.
            t
              • Jun 2010
              • 2796
              '03-'04 CTS manual trans.
              I have one... just need to build the Franken260 with 24V bellhousing, iX rear housing and Cadillac gears.
              • TobyB
                • 5296
                Thanks- now I have to troll the GM section, too, huh?
                So it's a different 1st and counter gear, then...
                t
                  • Jun 2010
                  • 2796
                  I assume so, but haven't looked up part numbers. There are differences in the 5th gear ratios that I see quoted on the net as well, so I may be able to put together a taller 5th too.
                    • Jun 2010
                    • 2796
                    Originally posted by digger
                    i use 391 with the CR G260 3.35/2.03/1.36/1.00/0.81
                    with a regular g260 a 3.46/3.64 would be closer to the money and be a better cruiser
                    Close ratio 260? Wasn't aware of such a thing.
                    The ratios you mention sound like an M3 G265.
                    was available in "euro" 325i "sport" models, also in oz BMW Australia spec'd a few hundred 325is with some goodies one of which was the box, SA 325is with 2.7L alpina spec engines got them to
                    http://www.e30zone.net/e30zonewiki/index.php/Drivetrain
                    GDMF. Now I have another Euro part to lust after. And I thought the Caddy gearbox was a good find.
                    Per E30zone the TNN code is the close ratio box.
                    RealOEM link:
                    http://www.realoem.com/bmw/enUS/part...&q=23001221138
                    PN's: 23001221572, 23001221138
                    Feh... so now I need to find a Sport G260 for it's 1st/2nd and use the Caddy 5th.
