Are the ring and pinion interchangable between LSD and open diffs?
  • loki_
    • Sep 2013
    • 147
    168mm small case e30 diff and 168mm ring and pinion. I'm pretty sure they are, but I just wanted confirmation. Thanks in advance.
  • agent
    Vice Grand Pubaa
    • 7960
    Yep.
    Originally posted by kronus
    • The Dark Side of Will
      • Jun 2010
      • 2796
      Not sure what the carrier break is for a 168 (or if there is one). It's 3.07 and down vs. 3.15 (3.25?) and up on 188's.
      • TobyB
        • 5280
        The 168 only goes down to a 3.40, and they're all the same carrier, that I've found,
        from 3.40 to 4.44. I haven't messed with the ultra- low 5.29, etc.
        + 1, it should swap.
        There is a good writeup that Andrew did on small case diffs over at the bmw2002faq.com
        t
