5 speed swap -- what do you replace "while you're in there"?
  • AC_Schnitzel
    • Sep 2017
    • 149
    As the title states.
    Planning to do a 5 speed swap soon. As parts are out of the car/uninstalled, what are things to R&R while there is more room available?
    How difficult is it to change the rear main seal while the trans is dropped, before I install the clutch?
    JP
    WTB: Z3 1.9 lever, plastic bumpers, 19# injectors, Anthracite Cloth Sport Seats
    Current
    88 325 super eta
    00 528i/5 (daily)
    02 530iA sport
    Former
    04 525iA sport
    87 325is
    91 325i
    97 528i
  • zaq123
    • Jul 2016
    • 1560
    rear main seal, engine/trans mounts...al new shifter linage bushings etc.
    I would also change all seals in the transmission while its on the ground. Also check preload washers behind input shaft seal for wear. One on my G260 had grove worn into it from the bearing outer race.
