Possible drive shaft issue
  • laidback93
    • Nov 2016
    • 435
    Driving on my way to work and start to notice a bone jarring vibration shaking the entire car when I got above 60mph. I have 90 325is manual.
    The vibration stops when I completely lift off the throttle.
    Am I having a drive shaft failure? I think I've isolated the source of the vibration to the rear end of the car. This makes me suspect the diff as well.
    I've had this E30 for almost a year and this issue just started today. There were no warning signs.
    Is it safe to drive back home which is 50 miles away? I plan to take the back road in order to keep it under 60. The vibration is so bad I need a spinal adjustment!
    Hope someone can shed some light.
    90 Bronzit 325is
    16 Black Sapphire 340i M Sport
  • Sea Aych
    • Apr 2013
    • 765
    Is it only happening when you accelerate? Or is it speed or RPM dependent?
    First go underneath and see if your guibo is shredded. if you have a flashlight and a mirror, you may be able to see the CSB behind the heat shield too.
    1988 Atlantisblau Euro/Japanese 325i Cabriolet
    1989 Schwartz 325i - now M50 powered! - now very dead
    1998 Toyota 4Runner Limited
    My 17,000km Big NA National Parks trip!
    • laidback93
      • Nov 2016
      • 435
      Only under acceleration. As soon as I lift off the throttle it goes away. I'll go see what I can see here in a minute.
      PS. Thanks to whoever moved this thread to the appropriate forum.
      90 Bronzit 325is
      • CrashandBurn
        • Aug 2017
        • 10
        Either Guibo or the center support bearing is shot.
        • laidback93
          • Nov 2016
          • 435
          Pretty sure that is the case even though I swear the PO replaced both. I mean why would you go to all the trouble of doing a Auto to Manual swap and not do that?
          Thanks for the feedback so far.
          I plan to get her looked at the beginning of October.
          90 Bronzit 325is
