Question about replacing ring and pinion.
  • loki_
    • Sep 2013
    • 147
    I have a spare medium case open 3.73 (188mm from an e30) and i plan on eventually swapping in a 4.10 or 4.27.
    If I remove the 3.73 ring and pinion to sell, are there any internal parts of the diff that I need to make sure I keep so that I don't screw myself when I go to have the next r&p installed in a few months?
  • TobyB
    • 5280
    When I have swapped centers around,
    the side case spacers seem to 'usually' stay with
    the case, and the pinion spacer 'usually' stays with the gearset.
    Or, that's at least a good starting place.
    hth
    t
    • SkiFree
      • Jun 2011
      • 2766
      t
      This needs to be emphasized. PINION SPACER STAYS WITH THE GEAR-SET, NOT WITH THE DIFF. It doesn't always work out, but at least 8/10 times. For the 2/10, you need to calculate the correct shim thickness. It's kinda a pain in the butt.
      ADAMS Autosport
      • TobyB
        • 5280
        It's a total and burning pain in the butt.
        I liked the old way, with multiple spacers of fixed thickness, better.
        But it makes sense for mass manufacturing to just use one spacer
        of variable thickness.
        Makes DIY a lot less easy, tho. And makes me think I need a surface grinder...
        t
