Whine that gets louder if the clutch is depressed? Recent full clutch job.
  • Daeldalus
    • Nov 2012
    • 304
    I replaced all my clutch components about 7k miles ago as part of a manual swap. Everything was fine until about a week ago when I got a power steering type sound. I drained old ps fluid and put in new synthetic atf. That changed nothing. I have been trying to chase down the noise ever since.
    I noticed that it was loud inside the car but not when I went to the engine bay. That led me to discover that the sound is louder when I press the clutch in. It is still slightly present when I am off the clutch but the sound at least doubles as I am pressing the clutch in.
    Throw out bearing? Transmission? I don't have a clue. All the clutch pieces are brand new. Trans was reseal ed and new fluid
  • AndrewBird
    The Mad Scientist
    • 11897
    Sounds like it could be the throwout bearing. Or maybe the pilot bearing. Going to have to pull the transmission to find out!
    • Daeldalus
      • Nov 2012
      • 304
      Would my transmission make a noise like that if it is low on fluid? I just noticed that it is leaking even though I just put new seals in it.
      • Daeldalus
        • Nov 2012
        • 304
        Why would my throw out bearing go bad in just 7k? I want to keep from having to do this job every 5 months.
        • e30davie
          • Apr 2016
          • 1788
          What sort of throw out bearing did you use? Good brand or a cheapy?
          It's possible, though unlikely, that your new throw out bearing has seized.
          • AndrewBird
            The Mad Scientist
            • 11897
            Improper installation maybe or just a faulty part. You won't know for sure until you pull it apart.
