Diff pinion bearing preload torque spec?
  • alpinewhite318i
    • 134
    I installed a new outer pinion bearing and seal on my small case 3.91 LSD diff and tightened the nut to the previous marks that I had made. Right now the friction torque is maybe 5-7 inches when I measure it with the beam style torque wrench. Is there a default range I should be using for the torque rating? I see the metric mechanic site is using 14 to 16 inch pounds?
  • TobyB
    • 5280
    There are 2 specs- one for new bearings, and one for used.
    I forget both. But the mm number seems right for a smallcase new bearings.
    The used bearing number was less- maybe 7-10? I forget. I found it
    in the E21 service manual. Which is... err... I forget where that is...
    If it was mine, I would tighten it to 10 inch-lbs of drag, run it for a while, and recheck.
    What I found, seat- of- the- pants, is that for whatever reason, sometimes with new
    bearings they could loosen more than I'd expect. Usually not a lot (10 degrees of
    the nut, or not enough to lose all preload) but I did have one get loose enough to where
    it clicked if you wiggled it. Caused all sorts of driveshaft vibes, too.
    I was using them semi- disposibly in a 2002 race car where they went in and out
    depending on tracks, so it was easy to check, and snug just a bit if needed.
    hth, just a story.
    t
    • alpinewhite318i
      • 134
      I was at 10 inch pounds and it seemed about right, then decided to go to 14 inches and it felt like the bearing was grinding. So I will start over again with a new crush sleeve. Do you recommend oiling up the bearing as well or using some kind of assembly lube? Thanks
      • TobyB
        • 5280
        I just used gear oil-
        and yeah, there's a point where it feels
        'too tight'- I dunno if it IS,
        but I redid them when they felt
        that way, too. Maybe that's why mine sometimes
        got loose...
        t
