weird single mass flywheel with reference pin
  • rede30
    • 4697
    I'm pulling apart a motor from an 87 325is. The flywheel is single mass but it has a reference pin. I know early etas have a single mass with reference pin but those flywheels are much thicker and heavier. This one is 18lbs 11oz. Anyone seen this flywheel before?
  • Andre3127
    • Dec 2017
    • 291
    It has probably been machined thinner to fit your car. Was your car manual swapped?
    Budget E30 Parts - Used and Reconditioned parts for your BMW
    • cunninglinguist
      • Mar 2004
      • 281
      Early 325i flywheel. 11 22 1 706 575
      • rede30
        • 4697
        Thanks so much. I was not aware there was an early i flywheel. realoem shows the cutout date as 12/86. They also list it as a "twin mass" but I always thought twin/dual mass means they are sprung.
        • cunninglinguist
          • Mar 2004
          • 281
          You are correct. The page title/section title in the catalog is generically called "Flywheel / Twin Mass Flywheel" regardless of what came on the car.
          But if you look at the line items, a description will indicate whether the flywheel is a "flywheel" or "twin mass flywheel". Refer to the descriptions for #8 on this page to see what I mean.
