Manual Swap: will a front manual drive shaft and rear part of a auto drive shaft work
  • AlexSutherland
    • Apr 2017
    • 41
    Swapping my 325i from an auto to a manual in a few weeks. I have a parts car that I pulled the engine and tranny with the front part of the driveshaft attached. The rear of the parts car has a large amount of rust and I stripped two of the bolts on the connection between the rear driveshaft and differential. I don't care for the differential, it's rusted to the point of no return. I really don't want spend the time getting the rear driveshaft loose. My question is can I just use the rear driveshaft from my current car?
    Parts car: 325e 1987
    My car: 325i 1991
  • lukeADE335i
    • Apr 2013
    • 1389
    Yes - there is sometimes a half inch difference in length between them, but that can be adjusted on the splines of the driveshaft, so it will work out fine.
    My e30: OEM+ with M30B35
    • AlexSutherland
      • Apr 2017
      • 41
      Re: driveshaft
      Thanks Luke!
      • Elysian
        • 674
        The halves are balanced together aren't they? If so you may need to have a driveshaft shop rebalance.
        • TobyB
          • 5298
          As long as you clock them correctly, it's worth trying it first.
          it 'usually' works out ok without a rebalance.
          But yes, the German way would be to have it balanced. I've had trouble
          finding a local shop that will spin it over 3k rpm, which is really pretty slow for
          our cars...
          t
