Transmission fluid leak between engine and tranny
  • michaelpark
    • Jul 2018
    • 3
    I have a major leak coming from between the transmission and engine. I'm pretty positive it's transmission oil considering how the transmission was pretty much empty, and my engine oil level was healthy. I've heard it could be the rear main seal, could it be anything else?
    Here is a photo of the leak:
  • Todd Black 88
    • Oct 2007
    • 3449
    If it was the rear main seal, it would be engine oil leaking out.
    If you are certain it’s transmission fluid, then the transmission input shaft seal is most likely the culprit
    Originally posted by codyep3
    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
    2001 silver/Blk 325 cabby. SOLD
    2002 325xit Sil/blk. SOLD
    2010 F650gs twin
    • jeffnhiscars
      • Jun 2011
      • 6010
      Unless you're running atf in your trans, how did you determine it wasn't engine oil
      Alice the Time Capsule
      • michaelpark
        • Jul 2018
        • 3
        I'm pretty sure it is transmission fluid because the trans leaked a little more than a quart, while my engine oil levels didn't change at all. I checked the transmission fluid levels yesterday and there was basically none in there. Is there any other way to check?
        • michaelpark
          • Jul 2018
          • 3
          Any idea on the parts/labor for that? What is involved in this repair? I just need to know since I'm a newbie mechanic on a budget.
          • Todd Black 88
            • Oct 2007
            • 3449
            No idea on cost, but it’s a tranny out job.
            2010 F650gs twin
