When pushing clutch in, makes a watery 'squelch'
  • HerbE30
    • Nov 2015
    • 538
    I went to start my car to go to work this morning and when pressing the clutch I heard what sounded like water leaving the system?
    I have NO IDEA what would cause that. Just kinda like a weird bubbly/squelch noise.
    20% Accurate
    Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.
  • E30SPDFRK
    • 5713
    Check the clutch master under the dash for external leaks.
    Byron
    Leichtbau
    • HerbE30
      • Nov 2015
      • 538
      I poked my head out under the car to listen and check for fluid dripping this morning when I heard the noise. It was definitively louder under the car, so I guess slave.
      What is a good replacement? Really want OEM but for 150$ difference, is Febi a bad idea?
      [edit] Replacement for Slave and Master.
      20% Accurate
      • jeffnhiscars
        • Jun 2011
        • 6011
        I used Febi hydraulics when I did my swap and have had zero issues.
        Alice the Time Capsule
        • Andre3127
          • Dec 2017
          • 291
          Check your brake fluid level and see if it dropped.
          Budget E30 Parts - Used and Reconditioned parts for your BMW
