What does the shifter arm even do??
  • Justbergy
    • Nov 2016
    • 41
    Hey folks haha, I am doing an m50 swap and also a manual swap using an old getrag 260 I got for pennies. I know its not the best combo but that is what I got lol. I was wondering what this transmission even does? it looks like it just holds the shifter in place during bumps or motor movements? I was planning on just making my own and not spending 80-120 bucks on one. I have a cnc machine so why not right? The question I need answered is.. is there any reason I need to really be precise on this component while making it? if i just get the lengths right and use hockey pucks or something as the mounts will that suffice? the shifting arm is in the link below...
    Thanks!
    Justin
    https://www.google.com/search?q=bmw+...RYRmVKrEuxhyM:
  • roguetoaster
    Biggus Tippus
    • 7830
    No pic/link that I can see.
    • Justbergy
      • Nov 2016
      • 41
      Think I put it on now.
      • ELVA164
        • 4861
        It's the pivot point for the shift lever.
        • roguetoaster
          Biggus Tippus
          • 7830
          Funny search terms "bmw e30 shifter arm cheap."
          I'd wager that you can get a used one shipped to you for less than $30.
          • Justbergy
            • Nov 2016
            • 41
            Paleeeease find me one haha.
            • glnr13
              • 1334
              If you have the shifter plate instead from some of the older models you can cut it up and mount it to the trans tunnel from the inside. You will have to experiment with shifter rod lengths but it makes for a really firm shifter cup with no play.
              • TobyB
                • 5298
                errr... yes, you could make one, but that's the sort of thing you might find
                (with the part number) on places like ePay for less than the material to make it would cost.
                edit- wow, maybe not- I just blew 15 minutes and didn't find one for under $150.
                Huh.
                There are a few critical dimensions, but then, you could also put the shift
                lever exactly where YOU like it...
                t
                races with a $19.95 ePay short shifter...
                • Justbergy
                  • Nov 2016
                  • 41
                  Haha. Great responses. And yeah I think I'm gonna make my own. I'm alittle curious on what one of the previous posts said about mounting a shifter plate to the trans rubbed. But really sure what that is but might investigate a bit
                  • glnr13
                    • 1334
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      Create an account on Row52.com and have someone pull one and ship it to you. I did this for a hard to find fuel rail for my S52 swap and got the part within a week.
