Trans removal on jack stands.
  • cEm30
    • Sep 2015
    • 21
    Is it possible to pull a g260 from a 325e while its on jack stands?
    Also how much of a PITA is it?
    Any recommendations other than buy a lift?
    Hints, tips or tricks.
    Thanks
  • IRON-E
    • 16548
    Long extensions and swivel sockets, other than that loosen up your engine mounts and be ready to put a jack under the A/C unit to tip when necessary.
    Vaya con Dios....
    @IRON-E30 aka Edwin:D
    • uturn
      • Dec 2010
      • 1010
      Remove your fan/radiator so you don't put indentations in it when you tilt your engine to get to the bolts.
