Are ABS and Non-ABS axle the same? I am putting an ABS axle on a non abs car and I cant seem to get the new axle to slide in I have been straining myself for the past 2 hours trying to get this in and I have had no luck, I have resorted to trying to hammer it into the trailing arm but I will if I have to. BTW same number of spline and the length varies because the can contract and retract. Oh and smart me didnt get a new lock plate before I tore into it and I destroyed the that was on there.
HELP re-installing CV shaft
Tags: None
The axles are not the same and on that early car may not be able to slide in all the way. The ABS axles have a ring around the outer edge for the pulse sensor and later trailing arms have a larger opening in the back side to allow for this.Adam Fogg- '88 M3
Common sense- It's the new 'gifted' -
The abs ring comes off and I removed it, but tonight when I was trying to hammer the new axle in I the bearing race just crumbled, and that is another main difference the non abs axle has a solid face on the innner end and the abs axle has an open bearing. I tried filing the splines down and even heating the splines in the trailing arms with no luck getting it in. I am stuck now and I hope someone locally has a non abs axle.Comment
I've put ABS shaft to non abs trailing arm, had no difficulties.
That inner joint difference you mentioned, look closer, I believe that the inner joint "end cap" has just fallen off.Current:
BMW 320i 2d 2.0 m20 -88
BMW 325i Cabriolet 2.5 m50 -88
BMW 316i touring 1.6 m40 -90
BMW 320i 4d 2,2 m54 -01Comment
The axles are the same indeed. The job can be a pain in the ass but when you use a paintheater (do you call it that?) to heat the hub splines for a longer time it should be pretty easy. Don't force the shaft to much as it's easy to fuck one up.E30 Euro-S50B30 Tracktoy
E30 M20B25 DrifttoyComment
huh, I have some pics but the new axle I got def, did not have a cap on the endComment
