confirming my research before swap
  • Slybeanx
    • Dec 2018
    • 518
    Hello,
    I've been doing plenty of research, but I just want to make sure I have everything down before I actually buy the parts.
    So my car is a 91' coupe german import with airbags, so therefore I can only use another airbag coupe/sedan transmission correct? The Verts and IXs had special transmissions, which would make it more difficult to change?
    That being said if my car is a 91' euro import with an airbag the easiest swap to do is another airbag 90+ E30 correct? And if I wanted to upgrade the engine later I could instead just do any E46 transmission? Just looking for verification to my knowledge before I go ahead with the major purchases.
    Thanks,
    Chris
    85% of the time i have no idea what I'm doing
  • Supadave
    • 1006
    I've done a few swaps and the air bag as nothing to do with the transmission, where are you getting this info?
    https://www.r3vlimited.com/board/sho...d.php?t=420591 5.3 LSA build in progress :devil:
    • TobyB
      • 5293
      Back to basics: What are you swapping??? Auto boxes???
      you can swap one transmission for another, an auto for a manual, a manual for an auto, and probably, with sheet metal work and a lot of curse words, an SMG out of an E46.
      The ix is a 4 wheels driven driveline, so yes, it's different.
      For the manual box, it makes no difference, except etas may have a deeper bell,
      and later cars have a smaller output flange.
      t
      just one source of misinformation on the interwebs. nets. thingys.
      • Slybeanx
        • Dec 2018
        • 518
        I'd have to comb through my history for it I think it was a bimmer forum post but they said it messed with the brake lines. Just like I said I wanted to make sure before I went ahead with it.
