The larger flange uses a larger diameter CV that will not fit into the subframe hole. The smaller E34 CV just barely fits through the subframe as-is.
Its internal spline went straight onto my E30 iX touring rear driveshaft, but it came *off* a typical E34 driveshaft. If you are piecing together a driveshaft, you can use an E34 rear section for the spline drive since E30 touring driveshafts are not exactly growing on trees.
