I was in process of removing driveshaft so i can drop tank. I jacked up the transmission (manual) about an inch and remove the brace. I changed the mounts while i had it out. The tranmission apparently shifted on the jack and now it is touching the top of tunnel and shifted towards passenger about 5 degrees. How do i fix this?
I cannot attach a pic so hopefully this works.
