Clutch master cylinder binding/clicking issue
  • reelizmpro
    • 9559
    The shop that did the swap on my 323i installed a new generic clutch master cylinder and installed the plastic elbow backwards and it broke. I installed a new hose/elbow and reused the clutch master cylinder. After installation, I now have a clicking noise when the clutch is depressed. It's coming from the clutch master cylinder and sounds like the rod is now binding. I've gravity bled the slave cylinder but can't build enough pressure to disengage the clutch. Anyone ever have this problem?
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
  • playdoh850
    • Jan 2011
    • 115
    Hey! I am having the same issue. What was the resolution?
    • reelizmpro
      • 9559
      I installed a new FTE clutch master and powerbled the system.
      88 M3 - LACHSSILBER
