So for some unknown reason the VD is installed on the output shaft(mine wasn't)big deal. Why not remove the nut,tap out the studs, and be done.
Removal of Vibration Dampener help needed.
-Brandon
'86 325es S50
'12 VW GTI Autobahn DSG
'03 540i M-Sport (sold)
'08 Jeep SRT-8 (sold)
For sale:
S50 TMS chip for SchricksComment
We did have it that way, but I don't know if we had to. Wow....you're in St Louis. Almost close enough to hear our cursing over here in Kansas City.
If you heard, "FUHHHHHHHHHHHHHHHHHHHHCK" and smacked your kid in the back seat for cursing you should tell him you are sorry and one of your internet friends set the record straight.
We removed the lock bolts holding the guibo onto the driveshaft, and pulled that sucker off there. You have to loosen the collar on the driveshaft to compress it sometimes, and it was a flaming biatch anyway. When we put it back on we'll swing the diff outta there to do so.
Or just leave the guibo out and pack JB weld in there. Probably have about the same chance of grenading.Comment
Na, it's sitting on the garage floor, same as it was a year ago. If I do anything with it, I'll probably do it after it's installed in the car. Otherwise, I no way to torque on the nut that holds on the output flange.-Brandon
'86 325es S50
For sale:
