Will the 5spd from a 1993 318i work in my 90 325is?
5spd from a 1993 318i into my 90 325is?
is it a getrag 250? you might have a problem with the bellhousing, see this link:
I was told by Treehouse racing the 318 and 325 trannys are identical in terms of the bellhousing and would bolt up with no problems. The 318 trans will even accept the M3 flywheel/clutch. Minor differences in the internals but nothing to worry over with a 318.
I'm using the 318 trans with my S52 swap so I'll have to monitor the wear somwhow...Comment
