Limited Slip with one wheel on Ice
  • lowd239
    • Dec 2006
    • 58
    Ive got a 87 325is so it has an lsd but im curious why there is almost no drive when one wheel is on ice while the other has traction. I replaced my differential oil with a redline fluid that has a lsd additive because previously the differential was clunking on slow speed turns. In the dry the inside wheel never seems to spin under acceleration on even the tightest of turns. It wouldnt really bother me except that to get to my garage I have to go up a back alley that is usually half covered with ice and my car struggles making it. Any thoughts?
  • T.Dot_E30
    • Mar 2004
    • 286
    your unit needs a rebuild.
    • lowd239
      • Dec 2006
      • 58
      ....makes sense. I checked out the clutchs on bimmerworld.com and it looks like they are 65 a piece. Is this a good deal? Also is it terribly difficult to change out the clutchs and are there any special tools needed?
      • Spinning Tires
        • Feb 2007
        • 283
        Weld The Spider Gears
        First: 1984 318i
        Second: 1987 325
        Third: 1987 325is
        Current: 1990 325i (Soon To Be 335i)
        • BahnE30
          • 1050
          do not weld the spider gears, parking lots will become 3 point turns, the disks are not bad to replace at all, you don't have to do any shimming. basically R&R.....
          • euroshark
            • Apr 2006
            • 3491
            lol, a solid diff is not good for handling
            Just get one from a junkyard or find a good one here / ebay.
            Though Im sure it wouldn't be THAT bad to replace the clutches...
            • Mr Deagle
              • 1121
              its only a 25% limited slip, so only the wheel with traction will get 25% of the power, and 75 percent of it will go to the wheel on ice, spinning it
              • Spinning Tires
                • Feb 2007
                • 283
                Weld The Spider Gears. You Can Tear Up Some Serious Snow And Ice. It Will Be Like 4WD. Then Can You See How Much Better The Car Is At Off-Roading
                First: 1984 318i
                Second: 1987 325
                Third: 1987 325is
                • Spinning Tires
                  • Feb 2007
                  • 283
                  P.S. Mr Deagle Knows His Shit. You Could Have A Brand New Posi And Still Spin One Wheel On The Ice. You Want Posi On Ice? Weld Em Up
                  First: 1984 318i
                  Second: 1987 325
                  Third: 1987 325is
                  • rede30
                    • 4697
                    why are all your words capatalized?
